Any way to add USB 3.0?
Solved by Mira Yurizaki,
2 minutes ago, star_pilot475 said:Oh ok, I thought you had to have a usb header for that but alright! Thanks a bunch!!
If you want a header so you can use your case's USB ports, there are cards that have one, like https://www.newegg.com/Product/Product.aspx?Item=N82E16815124120&Description=usb 3.0&cm_re=usb_3.0-_-15-124-120-_-Product or https://www.newegg.com/Product/Product.aspx?Item=9SIA6ZP8FA5411&Description=usb 3.0 expansion card with header&cm_re=usb_3.0_expansion_card_with_header-_-15-158-411-_-Product
