Factory OC-ed 290X or Reference 290X - both water-cooled
Maybe I need to re-word my question:
When water-cooling the 290x, should I be concerned about burning them out (or them dying before their time) when mining almost 24/7 with them?
From what I've seen, whether your card is great for mining or not is kinda a crapshoot. With them under water heat should never be a problem so what I would choose based on would just be price. Getting a custom pcb card will help for gaming but not as much for mining. The 290x is limited by power on the reference models when under water but when mining you usually leave the core clocks fairly low and just crank the memory so power usually isn't an issue. I would also expect the custom cards to have slightly better qc so that could be an advantage when running at 100% 24/7.
