This issue occurred day one. In games it doesn't matter what resolution or graphical settings I use, there is always stuttering
Spec:
Motherboard: Gygabite Aorus B450 Elite
CPU: Ryzen 5 2600
GPU: Nvidia GeForce GTX 1070 Asus Dual OC
RAM: 8GB 2400MHz BallistiX
PSU: 550W Elite V3 Cooler Master
What I've tried so far:
Rollback to 397.93 drivers
Increasing GPU power limit
Disable Game bar
I've attached 4 files in here. GPU-Z Sensor Log while running Furmark. Both normal and increased power limit while running Furmark and increased power limit while in game ( PUBG ). Frametimes can be literally insane causing a really big stutter as you can tell.
GPU-Z Sensor Log.txt
Increased power limit ingame.hml
Increased Power limit.hml
Normal power limit.hml
https://linustechtips.com/topic/1053116-gpu-power-drops-causing-huge-frametimes/
Is that one stick of ram?
@Slottr sadly, yeah
@Srijan Verma bought it couple of months ago and didn’t have much time for gaming. I knew I had that issue. First time I saw it in Fortnite but then I’ve read that new patch was causing stutter for people so didn’t pay much attention until now.
2 minutes ago, Marko96 said:
@Slottr sadly, yeah
so is that only in fortnite or other games too?
THIS IS MY SIGNATURE
1 minute ago, Marko96 said:
Every game. I was testing this in PUBG
One of my friends with a 1060 used to have this problem of stutter, we figured out his solution to be a lack of ram.
stuttering can be caused due to multiple reasons.
Since you said you had only 1 8gb stick maybe its what limiting you.
do one thing mid game go to the task manager and take a screenshot of your memory section maybe it is eating up your whole stick to the page memory
