You can set the voltage via Intel Extreme Tuning Utility BUT you will be lacking LLC, you will have to push extreme voltages to achieve higher clock speeds.
Z77/Z77M-D3H/DS3H boards are the shittiest Z77 boards you can get.
https://linustechtips.com/topic/1052831-3770k-overclock-issue/#findComment-12463933
That board does have core voltage its under MIT \ Advance Voltage Settings \ CPU Core Voltage Control
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1052831-3770k-overclock-issue/#findComment-12463936
My bad I thought i saw z77mx-d3h.
Yea i thing the M only can adjust dram voltage.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1052831-3770k-overclock-issue/#findComment-12463957
i tried,however i did not find a core voltage option as you can see
https://linustechtips.com/topic/1052831-3770k-overclock-issue/#findComment-12464020
I was able to control it with my Z77-DS3H, I guess gigabyte used an even worse VRM setup for that board. Then I am sad to say it but you are out of luck.
https://linustechtips.com/topic/1052831-3770k-overclock-issue/#findComment-12464046
