Hi everyone,
My super old logitech headset are busted and I am in need of a new one. I am totaly not in the loop for any current good headset brand at the moment and need suggestion on what to buy.
I am gonna use them mainly to chat with friend during some PC co-op game. Id prefer to get a wireless headset over wired one and I am not gonna use them more then a couple of hour each week. Battery life wont be a concern.
Price range : under 100$ canadian would be great.
https://linustechtips.com/topic/1051770-wireless-headset-suggestion/
Welcome to the forum!
Do you mind wired headphones?
You can get some Hyper X cloud ii for a bit over 100 cad.
https://www.amazon.ca/HyperX-Gaming-Headset-Nintendo-Switch/dp/B00SAYCXWG/ref=mp_s_a_1_6?keywords=gaming+headset&qid=1554449943&s=gateway&sr=8-6
Please mark as helpful and informative so my profile looks better.
quote or reply to me if you want me to reply to you.
Thanks
HyperX Cloud Flight if wireless.
Cloud Alpha or Cooler Master 752 if wired.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
I would prefer wireless, but if there's no great option around 100$, wired if fine.
The hyperX cloud flight are a bit over priced for me (almost 200$ for canada), the Cloud Alpha look great. Are they a refresh of the HyperX cloud ii ? the Cloud ii is from 2015 and the cloud alpha from 2017.
Is there a difference between the Cooler master 752 and 751? amazon list them both and seem the same.
Thank you all for the reply. It seem like buying a good headset is as complicated as getting all the part for a PC.
2
One of them comes with a soundcard and virtual 7.1 while the other doesn't. The price gap should be small enough to make the one with the soundcard a viable option.
And it's true what you say about audio gear. It's even harder if you start looking at it.
Also, the Cloud Alphas are the latest member of the HyperX CLoud family if you look at the wired models. They are more of an upgrade to Cloud (pro) than Cloud II since they do not come with an USB soundcard.
One my friend is currently using the steelseries artic 5(2016 version). Is it just as good as the other suggestion? The only real difference i can see is that the microphone is retractable instead of detachable.
My choice boil down to the HyperX cloud alpha, Coolermaster MH-752 and the Steelseries Arctics 5.
