Hello. I have a form made where the client wants a date input to only allow Sundays. I'd prefer to do this with javascript. Anyone know a way where I can get this to work? Here's what I have so far but no luck. ID for the html input with type='date' is 'endDate'
<script>
function onlySundays() {
    var selectedDate = document.getElementById("endDate").value;
    var dayNumber = selectedDate.getUTCDate();
if(dayNumber !== 0) {
    document.getElementById('endDate').value = "";
    }else {
</script>
https://linustechtips.com/topic/1051278-help-with-javascript/
Instead of this:
Use:
    var selectedDate = document.getElementById("endDate").valueAsDate;
Also, this bit returns day of MONTH, not day of week.
Use getUTCDay() instead.
https://linustechtips.com/topic/1051278-help-with-javascript/#findComment-12451109
17 minutes ago, WereCatf said:
Instead of this:
Use:
Even when just this is the script while the input has 'onchange = 'testing()'
<script>
function testing() {
document.getElementById('testing').innerhtml = selectedDate;
</script>
it will not output to a "<p id='testing'></p>" in the page. Even with just a regular .value. I feel like it just cant grab the value in the date input. Or I just don't know how to.
https://linustechtips.com/topic/1051278-help-with-javascript/#findComment-12451163
<script>
</script>
You cannot just write an object-type of 'date' to a web-page. You need to convert it into text or set it in an element that supports such a type, like e.g. as follows:
document.getElementById("testing").innerHTML = selectedDate.toISOString().substr(0,10);
Secondly, learn to use your browser's debug-tools. In e.g. Firefox, the console-log would've told you the error.
https://linustechtips.com/topic/1051278-help-with-javascript/#findComment-12451204
Okay will do I've just started learning programming a month ago. Good to know
https://linustechtips.com/topic/1051278-help-with-javascript/#findComment-12451251
