After installing windows 10 on a new SSD and booting successfully several times, I am no longer able to boot into it. Even though windows etc. Is on it; I simply get the black screen with ‘import boot media’ etc that one gets after first building a Pc. I have tried switching SATA cables, mobo ports and also know the cables work as I have accessed a HDD no problem. I’m lost at this point so any help would be appreciated!
https://linustechtips.com/topic/1050944-problem-with-ssd/
Boot type and order properly set in the UEFI?
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1050944-problem-with-ssd/#findComment-12448147
Have you  tried to use the boot options and selecting that drive?
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1050944-problem-with-ssd/#findComment-12448149
Sorry should’ve said this but I’ve completely unplugged any other drive in my system. My drive is being recognised but there’s like two sections (sorry I’m pretty nooby!); I’ll attach a picture. I’m not sure if maybe these are in the wrong order?
https://linustechtips.com/topic/1050944-problem-with-ssd/#findComment-12448168
3 minutes ago, AlanTonii said:
In addition; if I click the windows boot manager it boots straight in
you still have your HDD plugged in? If so remove it and try to boot.
https://linustechtips.com/topic/1050944-problem-with-ssd/#findComment-12448189
Thanks for all the help guys but I just solved it haha. Had a boot piority on that meant it tried to boot from the SSD before the windows section first - no idea why. Think all is good now haha. Tysm for all the replies though; nice to know there are people willing to help!!!
https://linustechtips.com/topic/1050944-problem-with-ssd/#findComment-12448193
