You can do either or
https://linustechtips.com/topic/1050347-wireless-access-point/#findComment-12443753
33 minutes ago, travisg96 said:
Do I need to connect my WAP to the router or can I attach it directly to my network switch?
A WAP only needs power to function, if you want to connect it to the network via a wired connection (some can work wirelessly) you will need to connect it to the switch (leading to the router) or directly into the router.
Short version: switch is fine.
https://linustechtips.com/topic/1050347-wireless-access-point/#findComment-12443757
