Hello!
So for the actually lights, they work, but what I mean by not working is its problem.
The lights wrok but only when I keep pulling back or putting pressure on the cable for the power.
They light up and as soon I let the power cable go the lights turn off.
Was thinking of them using in my setup, and I can't return them because their a few months old now.
Idk what to do
https://linustechtips.com/topic/1050251-led-lights-not-working/
4 hours ago, Vod said:
Hello!
Idk what to do
Take a photo of the connector you're referring to it sounds like there is a bad pin on the cable or solder joint to the LED strip.
https://linustechtips.com/topic/1050251-led-lights-not-working/#findComment-12443175
I have two of those connectors, tried connecting power to either but still had same problem.
https://linustechtips.com/topic/1050251-led-lights-not-working/#findComment-12443794
What connector are you exactly referring to? Sounds like a loose pin if it's the connector that directly interfaces to the PSU.
https://linustechtips.com/topic/1050251-led-lights-not-working/#findComment-12443900
2 hours ago, Vod said:
By connector I mean thease
Are the 4 pin adapters very loose, if so you may need some new ones or to replace the connectors on the end of the LED strip themselves.
https://www.amazon.com/ABI-Connectors-Color-Changing-Light/dp/B00KDLSX4Q
https://linustechtips.com/topic/1050251-led-lights-not-working/#findComment-12444873
On 4/1/2019 at 8:28 PM, ELECTRISK said:
Bust out some wire strippers and a soldering iron and solder the wires from the power supply to the connector pins and call it a day.
Or don't be as ghetto as me up to you.
How would I be able to change turn on the LEDs, change the colours...
https://linustechtips.com/topic/1050251-led-lights-not-working/#findComment-12450631
Do you have a RGB controller, those lights must use one to be able to change colors and different lighting modes.
https://linustechtips.com/topic/1050251-led-lights-not-working/#findComment-12454298
