8 minutes ago, LukeSavenije said:
if i read through it i'm thinking it's windows update failing...
After reading it a few times I saw it as this
'Hiii guys ibuy a system in i5 process' - Bought a system with an i5
'its take every day show starting PC fix the problem to restart in 100%' - It shuts down(?) everyday randomly and restarting fixes the issue
'itshow how to find my hard ware is problem to know' - How do I find out the specs of my hardware?
https://linustechtips.com/topic/1049878-problem-in-pc/#findComment-12439802
3 minutes ago, LukeSavenije said:
Great explosion
I think Cooler Master said it best when they said, "as sealed stick was removed, lost or damaged, it shall be out of warranty vailidity!"
27 minutes ago, _d0nut said:
google translate
For all you know, that WAS Google translate. :(
https://linustechtips.com/topic/1049878-problem-in-pc/#findComment-12439852
ah, cooler master and bombs
I should let you see something some day... i found a REAL bomb
will show you soon enough
https://linustechtips.com/topic/1049878-problem-in-pc/#findComment-12439858
