So i posted the other day on here about my stuttering it seems my problem with stuttering is somewhat gone but now i have another issue
So heres my build first off
Amd Ryzen 7 1800x
b450 pro4 mobo
16gb ddr4 3200mhz dual channel
gtx 1060 3gb
120gb ssd
240gb ssd
1tb hard drive
So the issue is my gpu while playing ARK is at like 16% usage? It still stutters a bit but its no where near where it use to be but the fact is my gpu is at such a low usage i have latest driver installed anyone have any ideas why this is?
https://linustechtips.com/topic/1049586-gpu-at-low-usage/
6 minutes ago, KhakiHat said:
What settings are you trying to run the game on? graphics, resolution, etc.?
Wait, so it is just that one game ARK ?  If this is the only game the GPU usage is at 16 percent then you have a solid system and video card and its a game issue or OS or driver tangling and what not.  If your keen on playing ARK then try to do a DDU "Display Driver Uninstaller" in safe mode and clean and reboot,, then back into normal mode install the latest WHQL drivers.  If problem persists then go to nvpanel and set everything to defaults which is crummy as you will lose AA and all the glitz and glamour, just to test.  If problem still persists go back to nvpanel and turn on all AA and all options you want and forget about ARK lol ! :(
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1049586-gpu-at-low-usage/#findComment-12437785
