The cooler master h500 - do I need more fans?
webguy
Hi.  I am building my first pc.  It will be used for gaming and streaming to twitch.  I have an i9 9900k and evga 2080ti black edition 2 fan gpu.  I plan to do moderate overclocking of the cpu.  I have bought a cooler master h500 case and I have a noctua nh-d15.  I will use the mesh front panel for the case.  The details on the case listed that it has two 200mm RGB fans that come pre-installed.  I assume those are the two fans in the front right?  It looks like it has one 120mm fan in the back though that was not listed.
My gaming and streaming sessions are likely to be 8+ hours long.  I do not want temperature inside the case to be a problem.  Do I need more fans?  If so then what do you recommend?  Thanks!
yes
Hmm I can see from the official site that it has a 120mm black fan at the back
preferably yes.  A pair of matching 200mm RGB fan or Noctua NF-A20 are both good options
Desktop benching:
1 minute ago, Jurrunio said:
yes
Thank you.  Yes it looks like it does have the 120mm in the back.  The front has two 200m rgb fans.  You mentioned I should maybe get two extra 200mm fans.  It looks like it says there is room in the top of the case for 2 x 120mm or 2 x 140mm or 1 x 200mm.  Since it only has room for 1 200mm fan in the top do you think that is the best option then?  I heard that noctua are really good fans.  I like that one you listed.  Do you think that the one noctua would be good then in the top?  Would that be intake or exhaust?  Thanks.
official site says it can mount 3 120mm, 2 140mm or 2 200mm.
Desktop benching:
I think that is in the front where there are already 2 200mm fans.  It says for the top it is only 2 x 120mm or 2 x 140mm or 1 x 200mm.  Would 2 x 140mm fans move more air and cool more than 1 200mm fan?
I'm now officially blind. Get a pair of 140mm then, more airflow than using other size of fans
Desktop benching:
Haha thank you.  These should be exhaust then right?  The two 200mm in the front are intake and the 120mm on the back is exhaust so I would think the fans in the top should do exhaust to help more hot air out of the case right?
top exhaust could make it into a negaive pressure system (more air pushed out than sucked in) increasing dust build up, but top intake will make it positive pressure which limits max airflow. It's your call.
Desktop benching:
Try it with the stock fans first and see how it is ? You can always add more fans later if need be. It is not like it is going to overheat with that default setup.
Thank you.  Would the two 140mm top exhaust be better cooling then?  I do not mind extra dust that I will clean out from time to time if it is better temperature and air flow wise.
Thank you.  I am worried with how much heat the 2 fan gpu will have so I am trying to get the best air flow I reasonably can.
I now think that adding two 140mm exhaust fans in the top would be the way to go here unless someone tells me that is a bad idea.  That would give me two 200mm intake fans in the front and one 120mm exhaust fan in the back and two 140mm exhaust fans in the top.
yes
Desktop benching:
17 minutes ago, Jurrunio said:
yes
Thank you.  I think I may do one 140mm or 200mm to keep it to more of a positive pressure than negative.  Thanks.
