Project Redo **** Complete****
So after my computer was Damaged,"Cough that is what I told my wife Cough".  The only issue the computer had  was one of the upper 90's popped off spilling about a cup of fluid into the computer, but the way it was setting when it happened fluid  got on a couple fans and spilled out the front of the case so there was no actual damage to the computer. But It gave me the excuse I needed to refresh the system.  ?
Current system Pre Refresh  intel  i7 5820K   CPU
                                               Asus Strix X99  Motherboard
                                               32GB Gskill Ripjaw 3200Mhz DDR4 4x8GB
                                               Nvidia GTX Titan X Maxwell
                                               5x 240/256GB SSD
                                               2x 2TB Hitachi HDD
                                               Phanteks Enthoo Evolv ATX non-temperd glass version
                                               EVGA 1000 W GQ PSU
                                               EKWB Custom Loop (EK Cryo-Fuel Navy Blue)
                                              NZXT Hue+
                                              Corsair AF 120mm Fans x4
                                              Corsair AF 140mm Fan x1
                                              Custom sleeved cable Extensions (Blue, White, Gray) Had issues with removed from system
Note:  After using this system with out flushing it for about 2.5 years all the EKWB @EK Luc Parts are very clean and have no signs of corrosion or damage. I am very pleased with the quality.
Post Refresh Parts
                                               intel  i7 5820K   CPU
                                               5x 240/256GB SSD
                                               2x 2TB Hitachi HDD
                                               Lian Li PC-011 Dynamic
                                               EVGA 1000 W GQ PSU
                                               EKWB Custom Loop Refreshed ( Light Blue) Sticking with blue due to some of the blocks and res taking on a slight blue tint.
                                              NZXT Hue+
                                              4x Deep cool SP Fans
                                              5x RGB Ring Fans
                                              Custom sleeved cable extensions ( Black Gray)
        Before
        After
https://linustechtips.com/topic/1049172-project-redo-complete/
