please help
Go to solution Solved by Guest,
You have given us zero to go on. What help do you need exactly ? You already own those parts ? If not then what is the question ?
What's up with your ram configuration?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1048966-please-help/#findComment-12432080
53 minutes ago, just build it said:
-snip-
is this a good for work stoishion
For doing what?  Using a basic term like "workstation" doesn't specify jack-squat.  Is the work using a calculator and spreadsheets?  Sure it'll do that.
You need to offer information that we can actually compare against this parts list.
Edited by LogicWeasel
https://linustechtips.com/topic/1048966-please-help/#findComment-12432187
