3 minutes ago, Brandon Knibbs said:
Is the changes normal because the core speed changes between 1596.19 MHZ to 3491.67 MHz and the multiplier
any heavy workloads? if not then it is the power savings. what are your temps on the cpu?
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
Just now, Brandon Knibbs said:
yy7.jpg.9b3d2f1cda373f413077db6033186576.jpg these are the temp for when my pc isnt doing anything
yeah power savings. it reduces clock speeds and voltage to save electricity
Build
how do i change it to get it back to normal
the bios. there must a settings. dont know which. look up your mobo model and power saving
Build
under load it will go back to normal
Build
