Hi everyone,
this is my build https://uk.pcpartpicker.com/user/Pro4TLZZ/saved/VXntgs
CPU: Intel - Core i7-8700K 3.7 GHz 6-Core Processor  (Purchased For £339.95)
CPU Cooler: CRYORIG - H7 49 CFM CPU Cooler  (Purchased For £34.98)
Motherboard: Asus - ROG STRIX Z370-E GAMING ATX LGA1151 Motherboard  (Purchased For £226.97)
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3600 Memory  (Purchased For £221.33)
Video Card: Sapphire - Radeon RX VEGA 64 8 GB NITRO+ Video Card  (Purchased For £439.72)
Case: NZXT - H700i ATX Mid Tower Case  (Purchased For £179.99)
Power Supply: SeaSonic - FOCUS Plus Gold 650 W 80+ Gold Certified Fully-Modular ATX Power Supply  (Purchased For £94.99)
Total: £1537.93
Generated by PCPartPicker 2019-03-26 22:04 GMT+0000
My cpu is running at stock clock with mce disabled and stock fan configuration at high performance profiles. I currently have a -90mv core voltage offset on my cpu, in prime 95 under ftt test it reaches 81. I suspect if i put the voltage back to auto then it will go to 90 degrees. I have repasted twice with mx4 paste. I am not able to increase the offset anymore without ram going unstable and windows refusing to boot. My ram has xmp speed of 3600mhz, i suspect i will not lose much performance if i change it to 3200mhz. Would changing it to that give me more voltage room to offset the CPU? and if so how would i go about setting the profile up in the bios?
Thanks
https://linustechtips.com/topic/1048547-help-with-cpu-temps/
19 minutes ago, Pro4TLZZ said:
81C on a 8700k that's not delidded on fft is fine, you'll never hit fft temps in real world loads, changing ram speed will not affect your cpu oc/temps. I suspect it's something to do with the vccio/sa voltages.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
https://linustechtips.com/topic/1048547-help-with-cpu-temps/#findComment-12428742
24 minutes ago, Firewrath9 said:
no, Are your case fans plugged in? also, what fan speed is the h7 running at? also, is your mounting pressure good?
also, is vcore voltage on auto?
Hi all case fans are plugged in. currently fan runs at 1578rpm when hitting high temps. Yes i believe so, have switched vcore to offset now and disabled xmp but on auto mode vcore can reach 1.316
thanks
oh buts its running stock so i assumed it would be cooler
thanks
https://linustechtips.com/topic/1048547-help-with-cpu-temps/#findComment-12428776
thanks
 thanks
you can prob run it at stock @ 1.18v
https://linustechtips.com/topic/1048547-help-with-cpu-temps/#findComment-12428902
