Help with deciding
Solved by MeatFeastMan,
59 minutes ago, Jukes2090 said:Actually i want to know which one is quieter. Not which one is faster.
https://www.guru3d.com/articles_pages/asus_radeon_rx_580_strix_review,8.html
https://www.techpowerup.com/reviews/Sapphire/Radeon_RX_590_Nitro_Plus/31.html
590 seems to be quieter. But if we're honest, you probably won't see the difference.
The big thing you should be considering here is performance. And that 590 is the winner obviously. So get that.
