Hi ,
I have a Sandisk Sd card 32gb class 10 , I've been using it for about a year and it has all my photos , documents . Last week , it stopped working ( It's corrupted)
without any reason knowing that i don't download suspicious files or visit any non trustworthy websites.
Can someone help me , i would appreciate it alot!
https://linustechtips.com/topic/1048433-sd-card-corrupted-help/
As Aimi said try it in other devices, but anyway it's actually pretty common for SD Cards to fail suddenly, if the data is really important to you then it might be worth it to send it to a data recovery service, and i wanna make it clear that you should not mess with it or use programs to recover it as you might lose your data probably forever.
Quote or Tag people so they know that you've replied.
https://linustechtips.com/topic/1048433-sd-card-corrupted-help/#findComment-12427777
Happened to me, try sd card partition recovery.
The SD card slot in my phone corrupting any card that are inserted.
https://linustechtips.com/topic/1048433-sd-card-corrupted-help/#findComment-12427783
Yes sometimes bad slot can corrupt the disk.
In my case it only corrupt the partition table, not the data, so when using partition recovery it can read most of the data completely.
One thing that you should not do is reformatting a broken disk, that will completely destroyed the data, it may not be recovered.
Try any partition recovery to find out.
Hopefully it can be solved with software.
https://linustechtips.com/topic/1048433-sd-card-corrupted-help/#findComment-12427926
