Hi. I have been having trouble with my RAM. I upgraded from a i5 5600 with 16GB DDR4-2400MHz to a Ryzen 7 2700 with 32GB DDR4-3200MHz. However, I can't get my computer to recognize that it is running at a 3200MHz and not at the displayed 2133MHz. Is this just a graphical issue? Or do I need to start messing with the voltage and other frequency settings within the BIOS in order to run at the desired 3200MHz? I have already looked at the BIOS and tried to edit it there with, obviously, no solution. Any tips are greatly appreciated. Thank you
https://linustechtips.com/topic/1048272-ram-help/
  • 2 weeks later...
your ram is not compatible with ryzen probably due to old sku, so it runs on standard freq. i cant remember what the amd equivelant of xmp profile, and it probably doesnt have one but adjusting the memory freq is the easiest way to go.
i dont know what your motherboard or ram is, but check compatible list on your board's product page is a start.
why everybody post the spec of their rig here? i dont! cuz its made of mashed potatoes!
https://linustechtips.com/topic/1048272-ram-help/#findComment-12454051
Is there an XMP or DOCP option in your BIOS?
AMD Ryzen 5800XFractal Design S36 360 AIO w/6 Corsair SP120L fans  |  Asus Crosshair VII WiFi X470  |  G.SKILL TridentZ 4400CL19 2x8GB @ 3800MHz 14-14-14-14-30  |  EVGA 3080 FTW3 Hybrid  |  Samsung 970 EVO M.2 NVMe 500GB - Boot Drive  |  Samsung 850 EVO SSD 1TB - Game Drive  |  Seagate 1TB HDD - Media Drive  |  EVGA 650 G3 PSU | Thermaltake Core P3 Case
https://linustechtips.com/topic/1048272-ram-help/#findComment-12454415
