Ok,
So,
For a while now I have wanted to do this. I live in Australia and I have wanted to setup an in pool cinema so we can relax in the pool at night and watch a movie. So boys, this is the criteria.
So I was thinking about buying a NUC and waterproof it with a container or something. I looked into a Rasberry Pi, but it runs Chromium and wont be able to run Netflix (i know that there workarounds but they seem too difficult)
Right now I am thinking about building a Mini ITX PC and search for a waterproof case or just waterproof it myself. But I am definitely open to suggestions.
I am pretty sure I am going to go for a normal size projector, I dont need anything special like 4k or sRGB or whatever, because I dont want to spend too much. It doesn't need to be waterproof or anything because it will probably be cheaper just to build a waterproof case that I can put the projector and PC in.
The pool is around 10m by 3/4m and I am probably going to put it across the width. I dont need a screen but, I would like to see what options there are.
Like I said, I want to spend minimal. So I am open to different ideas, but that is what I am thinking as of now. Please make sure all parts can be bought in Australia.
Anyways, thanks in advanced.
Oliver
idk tbh
https://linustechtips.com/topic/1047631-outdoor-pool-cinema/
