I'm wanting to mount two monitors vertically, only problem is they don't have vesa mount holes, i know its possible to get adaptors or brackets to convert a create a vesa mount but non of these are suitable to turn the monitor vertical. I'm not wanting to buy another 2 monitors but is that gonna be the only way of doing this?
cheers for any help
https://linustechtips.com/topic/1047563-non-vesa-vertical-mount/
cheers for any help
Welcome to the Forums!
It's possible to make a mount for them but it depends on the monitor. Ideally if you can use the original stand that would be a solid mounting point to then attach a VESA adapter plate.
