Hello so I just started watercooling and I feel like my temps are to high. I have the 2080 ti water cooled at temps while playing at 4k ultra settings averaging 85 celcius. I dont know if that is normal temps to be getting while watercooling. Any advise or tips? I have 2 360 radiator going to cool.
https://linustechtips.com/topic/1047508-2080-ti-temps/
That's certainly high, but then it also depends on CPU. I'm not surprised with its temperature if there's an overclocked W-3175X in the same loop.
Desktop benching:
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12419840
2 hours ago, Ravendarat said:
That’s way higher than my 2080 ti on a stock cooler
Yeah. So I'm not sure why I'm getting these temps. I've just took apart the waterblock and reapplied the thermal paste and made sure everything was nice and seated. My flow goes from pump to GPU to radiator to CPU to radiator to pump. I have my top radiator fan blowing, my front radiator I have pulling. I dont know if type of coolant matters but I'm using the primochill vue.20190321_212636.thumb.jpg.2a8357c69f090d4db6efb247ffba2e99.jpg
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12420508
I'm just using the i7 9700k. Nothing is overclocked. I'm still pretty new so dont want to mess with OC yet.
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12420517
are the fans all spinning at the same direction? Otherwise it will be recycling warm air.
Also open the side panel and see if temperatures get any better.
Mounting pressure is also a thing to check
Desktop benching:
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12420542
My GPU is vertically mounted and only an inch or so from my side panel, I have 3 120mm fans on the front and then a 120 on the back as an exhaust and the fans on my AIO blow out the top, I ran a stress test and my card maxed out at 78 degrees, my variant is just an EVGA 2080 ti xc and its overclocked 750/75
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12420668
I opened up the front and side panel and got a constant 55 Celsius. So it's most likely due to airflow. How should I orient my fans to optimize airflow. I have the dark base 700 case
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422361
Is that doll sitting on the gpu? Have more photos of this rig? (Can refer to other post if i missed that)
(Sorry, cant help with the temps but am now curious of the "showcase" ?
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422539
Yeah its sitting on the GPU. Still waiting on my cable mods to come in but besides that its basically done. Now I just gotta figure out this temp.
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422560
Front and top, one should be exhaust and the other intake. Now that I noticed you dont have a rear exhaust fan as it was blocked by a tube, too bad.
Wont it melt? GPU backplate can get hot enough to melt plastic.
Desktop benching:
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422680
Which one do I do intake? since you said top and front should be exhaust those are the only fans I have. 3 on top and 3 in front. I have the be quite silent wings 3 for fans. Should I swap then out?
The figurine is made from ceramic plus I put some thermal pads under it to help as well.
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422714
Front should be Intake, and Top should be exhaust normally. Fans should be fine.
My 2080ti is always around 83-85c while gaming even with 100% Fan speed Should i worry ?
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422723
I mean either it's top intake front exhaust, or top exhaust front intake. I mean, maybe you want the system to blow warm air towards you, maybe you dont, up to you.
Silent wings 3 are good at lower noise levels, though dont spin that fast at max speed so you cant blast them to improve cooling further.
Oh I though that's plastic, then your card could burn itself without hurting the doll :P  Are there extra support for the card though?
Desktop benching:
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422728
Okay I will have to fiddle around with my fans to see which is best and probably throw my 140mm fan on the back for extra exhaust. But I dont have a support for the card. Should I?
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422748
You'd better give support to the card. While taking the heavy heatsink off usually means you dont need support, a ceramic doll isnt light and does stress the PCB and PCIe slot. Also it could be applying pressure to your loop which is the last thing you'd want to take force.
Desktop benching:
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422801
Okay but with the support of my loop it sits the same as it would with or without the figurine on it. But a $10 support bracket is better then a broken $1300 GPU.
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422815
Dont even need a support bracket, a pile of coins on the right end of the card will do.
Desktop benching:
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422817
Well you're doing something wrong.
My 2080 Ti is 41C at 100% usage.
2nd one is at 35C.
With a single 360mm rad you should be seeing 50-60C but not 85C.
Reapply thermal paste / use better one?
Ramp up the fans and see if there's difference?
Use smoke to check if there's enough airflow?
Main PC:
CPU: Intel Core i9 14900KS SP 109 (125P-79E) (6.1Ghz P-Cores 4.8Ghz E-cores) MC SP 88
CPU Voltage: LLC6 1.43V
Cooled by: Supercool Direct Die 14th gen full nickel
Motherboard: Z790 ASUS Maximus Apex Encore
RAM: GSkill TridentZ 2x24GB DDR5 8800Mhz Watercooled
GPU: RTX 5090 Palit OC with Alphacool Core Waterblock
Case: TT P3
Storage: 4x 2TB Sarbent Rocket Plus Gen 4.0 NVMe, 1x External 2TB Seagate Barracuda (Backup)
PSU: Corsair AX1600i with custom black and red cables with 2x Corsair 5V+ Load Balancer
Display: Samsung Oddysey G9 57" 240Hz Ver. 7680x2160 and
2x ASUS XG17AHP 240hz 17"
Fan Controllers:  6x AquaComputer Octo
Cooling: Three Custom Loops:
1st Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for GPU only cooling with 2x Koolance QDC3, red coolant
2nd Loop: 5x 480mm XE CoolStream radiators with 1x Revo D5 RGB pump and 1x Rajintek Antila D5 Evo RGB pump for CPU only cooling with 2x Koolance QDC3, purple coolant
3x 360mm PE EKWB CoolStream
3rd Loop: 1x 240mm PXE CoolStream radiator with 1x EKWB Revo D5 pump (RAM ONLY) - Back of the case
2nd Main PC is same as above, except Display is Philips Evnia 49" 5120x1440 240hz QD-OLED, 48GB 8400Mhz RAM, 8TB NVMe
1st LaptopMSI Titan HX18 Dragon EditionRTX 5090 175W, Core Ultra 285HX,  128GB of RAM @5600Mhz / 96GB @6400Mhz
8TB of NVMe - GPU and CPU with LM on, Llano V12
2nd Laptop: MSI Raider 18HX, RTX 5090 175W, 9955HX3D, 128GB DDR5 @5600Mhz, 8TB NVMe, CPU and GPU LM on, Llano V12
3rd Laptop: MSI Titan 18HX, RTX 4090 175W, 14900HX, 224GB DDR5 @3600Mhz, 8TB NVMe
HTPC:
CPU: Intel Core i9 14900K (SP99 P111 E76), CPU Voltage: 1.33V, Cooled by: Supercool Direct Die 12th gen full nickel, Motherboard: Z790 Apex
RAM: GSkill TridentZ 2x24GB DDR5 8000Mhz CL40, GPU: RTX 5090 Palit Gamerock with Alphacool Waterblock,  Case: Corsair 6500D, Storage: 3x2TB PM9A1 Samsung NVMe Gen 4
WiFi: Wifi 6E Built in, PSU: AX1600i Corsair Titanium, Display: Philips Evnia 49" 240Hz OLED, Fan Controllers:  1x DH-10 DeepCool and Deepcool RGB hub, Loop: 2x 360mm XE CoolStream radiator, 1x 360mm PE Coolstream Radiator, 1x 240mm XE CoolStream Radiator, Revo D5 EKWB Pump, 19x Corsair 120ML RED LED fans 2000RPM
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12422880
2nd one is at 35C.
I just reapplied thermal paste the other day. I'm using the grizzly thermal paste. I'm getting 55 celcius with my front panel and side panel off. I think it's my case that's restricting airflow. My top panel only has one section for air vent and my front has none. I'm using the dark base 700. Which case are you using?
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12423094
That's still way too high for 2 360 rads unless your ambient temp is in the 40's.
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12423401
Remove ALL air filters.
Main PC:
Case: TT P3
HTPC:
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12423674
14 hours ago, thelongcheng said:
Yeah my ambient was pretty high. We had our heater on at 70 when I did this. But I opened a window to let some cold air in.
I meant in the 40C range. With a typical in door ambient, you shouldn't really have any problems keeping your GPU in the high 30's or low 40's.
https://linustechtips.com/topic/1047508-2080-ti-temps/#findComment-12426214
  • 1 year later...
