Do I need to upgrade my memory for my new parts?
Solved by Findiculous,
8 minutes ago, opienick said:Yeah I realized it was DDR3. What about this brand? Comes in a 16GB kit. And yes, I know how much I need quantity wise, just not sure at all about which kind. Example, should I pay to buy the Corsair instead of this brand, etc.
Im not familiar with the brand though you can get a similar price:
or
In any case its up to you what you go with. Just make sure its DDR4 and again I would recommend 16GB minimum for your purposes.
