Keyboard help
Go to solution Solved by Jurrunio,
it's F2 or Delete key, most BIOS accept both. You can use 60% keyboard, most of them have both keys function represented by pressing two other keys at once (say Fn key with 2 key for F2)
So i just had a random thought and is kind of bugging me. I know you have to press a certain key to enter the bios screen when you first boot it up (and which key btw do you press) and im thinking of getting a 60% percent keyboard so is it fine or do i need to start with a full keyboard?
https://linustechtips.com/topic/1046939-keyboard-help/
Desktop benching:
https://linustechtips.com/topic/1046939-keyboard-help/#findComment-12415374
the specific key varies depending on the manufacture.  When it comes to pretty much all custom builds, it is usally delete when it comes to pre builts or oems, it varries between the function keys
Current Rig=  AMD Ryzen 9 5900x, Asus Crosshair Hero VIII, EVGA RTX 3070 FTW3 ultra, 32gb Corsair Vengence Pro RGB 3000hz White, EVGA 750 P2 PSU, 1TB Samsung 980 Pro, 500gb samsung 860 evo, 250GB Samsung 850 evo, 2TB Samsung 970 Evo Plus, 2TB seagate firecuda sshd,  LianLi PC 011 Dynamic XL ROG edition, Corsair h150i elite capelix
https://linustechtips.com/topic/1046939-keyboard-help/#findComment-12415375
