So I randomly came across this video today. Do you think it would be viable in a custom loop without ice? I'm thinking this could be a game changer. The temperatures are impressive, but I have to admit that I'm still skeptical considering that there's ice involved. At the same time, I did not expect this to work at all even with ice.
https://linustechtips.com/topic/1046632-liquid-air-cooling/
Commercially available CPU waterblocks already implement this idea of water going through a fin stack instead of air. I think that since you have a larger heatsink to transfer heat to the water vice a regular waterblock, you will have better initial temps but will ultimately hit a certain thermal limit which will be dependent on the radiator and not the heatsink anymore.
Cool idea, hopefully he does a complete set with radiators.
https://linustechtips.com/topic/1046632-liquid-air-cooling/#findComment-12412216
