CPU
Intel® Core i9 9900K 8 Core 16 Threads
Motherboard
ASUS® ROG Strix Z390-E
Memory (RAM)
32GB Corsair Vengeance Pro RGB
Graphics Card
MSI RTX 2080 Gaming X Trio
1st Drive
500GB Samsung 970 EVO NVME
2nd Drive
1TB Samsung 970 EVO NVME
3rd Hard Disk
480GB KINGSTON HYPERX 3K SSD, SATA 6 Gb/s (upto 540MB/sR | 450MB/sW)
4th Hard Disk
2TB 3.5" SEAGATE SSHD, SATA 6Gb/s 7200 RPM
5th Hard Disk
Power Supply
CORSAIR 850W RM SERIES™ MODULAR 80 PLUS® GOLD, ULTRA QUIET
Processor Cooling
Corsair H150i Pr 360mm AIO
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1046503-connectors-problem/#findComment-12410962
13 minutes ago, Aljaz said:
Really bad explained on this video. Dont even show the cable that goes to the connector. Still dont know which cable is pump cable, which is cpu cable....
He is literally talking about it at 4:24 when saying which header he is connecting the pump. He then goes into the cables a minute later which includes the fan headers.
Regardless, when in doubt, consult the manufacturers manuals that came with your mobo and aio
CPU
Motherboard
Memory (RAM)
Graphics Card
1st Drive
2nd Drive
3rd Hard Disk
4th Hard Disk
5th Hard Disk
Power Supply
Processor Cooling
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1046503-connectors-problem/#findComment-12411107
When
fans are spinin and pump its working I think. But no RGB colors working. Plus no display on MONITOR
https://linustechtips.com/topic/1046503-connectors-problem/#findComment-12411190
How should I know which cable is pump? He is just talking where to plug the pump not explaining which cable is that.
https://linustechtips.com/topic/1046503-connectors-problem/#findComment-12411193
1 minute ago, Aljaz said:
When
RGB needs to be connected up to the RGB headers. Once again the video talks about that.
As for display - thats a different issue if you have a GPU installed. Make sure you have connected the display to the GPU properly. Also make sure the GPU is seated properly in the slot and the power connector is plugged in properly.
CPU
Motherboard
Memory (RAM)
Graphics Card
1st Drive
2nd Drive
3rd Hard Disk
4th Hard Disk
5th Hard Disk
Power Supply
Processor Cooling
Case:
Lian Li O11 Air
https://linustechtips.com/topic/1046503-connectors-problem/#findComment-12411197
Yes the gpu is plugged in with 8 pin PCI cable. The display port is screwed in and the gpu was reseated 10 times now... i dont have no other connector then 4 pin and 3 pin cable that came with the cooler (other cables are not connectable with motherboard (cables for the color contorl switcher)
https://linustechtips.com/topic/1046503-connectors-problem/#findComment-12411231
