Hi!
I'm getting huge frame drops while playing Metro Exodus. And also other games.
My specs are:
Cpu: i5-3470, 8gb of 1300MHz ram
Gpu: RTX 2060
(possibly bying a new cpu this week)
I was told that it would be a bottleneck, but I would be able so play with a little better performance until I bought a new cpu. So is it because of drivers, Windows update or the cpu, I have huge frame drops. I didnt experience them with my gtx 970
When I bought the rtx 2060 i didnt get much difference in fps compared to my gtx 970 (max 5-10), is this because of my cpu? Or could it be something wrong with ny rtx 2060?
https://linustechtips.com/topic/1046414-frame-drops/
It's most likely the CPU. That CPU (in theory) should be able to handle up to a gtx 1060/RX 580, and your graphics card is significantly more powerful than either of those. Try installing MSI Afterburner or a similar program to look at the CPU usage while in games compared to the GPU. If the CPU is at 80% or higher for most of the time, you may need to grab a new one.
 CPU: I9-7900X RAM: 64GB (16X4) DDR4-2933 GPU: RTX 3080 MOBO: ASUS X299 Deluxe PSU: Corsair RM850 SSD: ADATA XPG SX8200 PRO 1TB HDD: Seagate Barracuda 2TB Case: Corsair iCUE 465X Cooler: Corsair 280 AIO
https://linustechtips.com/topic/1046414-frame-drops/#findComment-12410092
The gpu %usage is really low, and the fans arent even on.
https://linustechtips.com/topic/1046414-frame-drops/#findComment-12410098
Weak CPU, only 4 threads, only 8GB of RAM...you need a better platform to compliment that 2060 GPU otherwise it'll be hit and miss depending on the game...most demanding stuff will have framedrops and inconsistent performance.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/1046414-frame-drops/#findComment-12410101
because the rest of the machine is holding back your graphics cards...time for upgrade...
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.99 @ Amazon)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($114.99 @ B&H)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($89.99 @ Amazon)
Total: $369.97
Generated by PCPartPicker 2019-03-20 10:01 EDT-0400
https://linustechtips.com/topic/1046414-frame-drops/#findComment-12410106
17 minutes ago, Polariux said:
Hi!
My specs are:
Gpu: RTX 2060
1
You'd need to upgrade your system.
Two ways:
1st - Upgrade to i7 3770(K) and additional 8GB of RAM - choose this route if you're tightly budgeted without huge upgrades in the near future
2nd - change your platform (to a Ryzen 6-core or Intel i5/i7 with 6 or more cores), this includes the CPU, MBO, and RAM. Twice the price of the 1st option, way better overall.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1046414-frame-drops/#findComment-12410116
The ram is crap.... I think it cause a bigger problem than the cpu....
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1046414-frame-drops/#findComment-12410190
