PWM splitter
1 hour ago, David_Kwan said:Mhm.. have no idea what DC fans are. I thought there were only 3pin, molex and 4pin(pwm) fans. (There's a lot left that I need to learn I see..)
Though I read that you can plug the rear exhaust to the cpu opt header to have it's rpm synced with the cpu cooler?? Is this recommended?
I'm using the stock cooler that came with the R5 2600 so I can't really make good use of it since it's not like those tower coolers.
2pin, 3pin, and molex powered fans all use dc. 4pin pwm fans can also be controlled with dc but that's not the point of pwm fans.
The cpu_opt might share the same fan settings as the cpu_fan header or it might not. You can check the available settings to be sure. Whichever you prefer is up to you and either is fine as long as your temps are kept in check.
