high load = high fps
high temps = Nope, 57C is the opposite of high
1500: This memory usage? Still very low, newer games easily use twice if not three times of that.
Desktop benching:
what about the GPU clock its in the red ? 1800 ?
more of this = more speee. All Pascal cards go past 1800 under 3D load.
6 minutes ago, TheRiskk said:
is 45ish idle normal temp?
idle temps are directly tied to case temperature, as long as it's not 60C+, only full load temperatures matter
Desktop benching:
should the idle temp be below that without the GPU fans spinning? they are currently on 40% and under load on BFV high settings it maxes at 65 i believe
also is it normal that the core clock is on 1500+ while idle ??? thats not under pressure?
it can totally be lower, and there's no lower limit for temperatures. Lower is always better, as long as you're fine with the fan noise.
did you use "high performance" power plan in Nvidia Control Panel? Keep that on "optimal power"
Desktop benching:
