3 minutes ago, mattydune said:
i'm looking right now at the intel pentium g5600, it says the instruction sets are SSE4.1 and SSE4.2, nothing more
Oh, that.
Doesn't matter unless it's super old
Ryzen 7 3700X / 16GB RAM / Optane SSD / GTX 1650 / Solus Linux
https://linustechtips.com/topic/1045338-cpu-instruction-sets/#findComment-12400424
CPUs with a lower instruction set can do the same tasks as CPUs with more, it just takes more time to do some of them. A wider instruction set allows CPUs to perform some tasks more efficiently. Generally it doesn't matter on modern CPUs though.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1045338-cpu-instruction-sets/#findComment-12400435
Some old CPUs, if missing certain instruction sets, won't work on some apps that need it. Apex Legends and SSE3 comes to mind.
i5-14600KF // 120x38MM Cooler Master AIO // B760i // 64GB DDR5 6000 // PNY RTX 5070 // Cooler Master NCORE 100 Max // Cooler Master V SFX-850 Gold // UWQHD AOC Display
https://linustechtips.com/topic/1045338-cpu-instruction-sets/#findComment-12400439
