Hello, I going to be building a fairly high-end system and I just wanted some confirmation that everything is good. I am the type of person that wants to have the whole build planned out to the T before even starting it, and I don't want to have to buy extra parts mid-build, so that's why I am checking. I am especially concerned about how the configuration of the RGB fans will work, considering there are 9 of them. I will include a sketch below of how I think it will work. Any help is gratefully appreciated.
(I have my reasons for the CPU cooler, pls don't judge)
RGB fan configuration
960240780_PotentialCorsairRGBFanWiring.thumb.png.f433f6c1b99bc39b59caef40e1e1b0fc.png
The AIO will be front-mounted in a push/pull intake configuration.
Specific questions:
1. Is the fan wiring configuration shown above correct? Also, is it okay to have the one commander pro connected to the other, and will that affect any of the addressability of the fans or lighting strips?
2. Because of the front intakes, it will be a 6 pull, 3 push configuration. Is this something to worry about?
3. Are there any bottlenecks in the system, or components you would suggest changing either for aesthetic or performance?
Thanks in advance!
https://linustechtips.com/topic/1045215-rgb-build-confirmation/
1/2) I would personally use in-wins RGB fans, as they are less of wiring hell, and dont require all the commanders
3) I suggest getting a 4TB SSHD, instead of an SSD, to save a lot of money, to spend on games and keyboards
i7 6700k, GTX 1080, Crucial MX 300, Maximus VII Hero, WD Blue, 16 GB RAM
https://linustechtips.com/topic/1045215-rgb-build-confirmation/#findComment-12399369
