Upgrading my PSU Help!
Solved by Spotty,
12 minutes ago, roundhouseboy11 said:I currently have an ultra HS750 psu which is very low quality.
19 minutes ago, roundhouseboy11 said:Currently in my PC, all of the cables that run from my psu are very well organized and are hardly visible which took me a lot of work to do. When I upgrade can I simply unplug the cables from my old psu, replace it with the new psu and then just plug the cables back in?
ABSOLUTELY NOT!
Only use the cables that come with the RMx unit (or aftermarket cables designed specifically to be compatible with it)!
