cannot say, that's why upgrading prebuilts are a pain. The PCIe slot works, but the BIOS might refuse to cooperate.
Desktop benching:
https://linustechtips.com/topic/1044812-gpu-help/#findComment-12396341
11 minutes ago, tahmid133712 said:
I do have an aftermarket PSU which is up for the job but is that GPU compatible with my motherboard?
I've upgrade a bunch of old Dell Optiplexes with new video cards, although sometimes it doesn't work.
You'll just have to try it out for yourself.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1044812-gpu-help/#findComment-12396351
I mean I already have a Ghost XFX HD 7870 in there and it's running fine. I'm worried about the RX 570 cos it's a newer card. If the 7870 is working fine then does that mean that the Rx 570 will be well?
https://linustechtips.com/topic/1044812-gpu-help/#findComment-12396394
it should in this case. I've made an RX 470 work on socket 775 platform so this prebuilt, based on 2nd gen should have no problems.
Desktop benching:
https://linustechtips.com/topic/1044812-gpu-help/#findComment-12396401
Thanks for the reassurance ? now I can sleep well tonight. It's my first actual PC upgrade apart from when I actually modified the OEM
https://linustechtips.com/topic/1044812-gpu-help/#findComment-12396463
