I have some question about my psu selection, I have been looking at a fanless option the (silverstone nightjar)
I was thinking is it a good option seeing I'm using a silverstone sg13 I'm worried it might overheat and cause more problems, can anyone advice?
And if anyone can suggest a 120mm  AIO with a good quiet pump.
I'll also be using corsair's ml fans for quiet fans.
I'm trying to get my system as quiet as possible.
My Main System :  https://pcpartpicker.com/list/Hk4pcY (Silverstone Sugo SG13W)
My Home Gaming Pc : https://pcpartpicker.com/list/Hk4pcY (Silverstone RVZ03)
O
https://linustechtips.com/topic/1044620-silence-build-question/
1 minute ago, seon123 said:
Fanless PSUs expect there to be some airflow from the case fans. If you want a quiet PSU, just get a quiet PSU.
Can you recommend a quiet psu?
O
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394615
im not sure if i would go fanless. the case doesnt look like it has a lot of airflow. just get one that turns the fan off at low loads.
the key to low noise is low rpm meaning no restrictions. and then once you get there and everything is silent like the fans and the psu and no coilwhine from the gpu if youre lucky then you will start noticing other sounds more and things like the pump adn harddrive noises will become more prominent
"You know it'll clock down as soon as it hits 40°C, right?" - "Yeah ... but it doesnt hit 40°C ... ever  😄"
GPU: MSI GTX1080 Ti Aero @ 2 GHz (watercooled) CPU: Ryzen 5600X (watercooled) RAM: 32GB 3600Mhz Corsair LPX MB: Gigabyte B550i PSU: Corsair SF750 Case: Hyte Revolt 3
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394617
I'm hoping the only sound comes from the 10tb hdd and nothing else.
O
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394633
im just saying the lower noise everything else is the you gonna noice the small stuff.
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394640
4 minutes ago, seon123 said:
Not without knowing what PSUs are available and what you're going to power.
I can get almost every psu thru newegg, amazon, ebay or  sim lim
O
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394651
4 minutes ago, campy said:
the beautiful whine of a WD gold spooling up and down is extremely noticeable when the rest of your system makes no noise at all
had a system testing recently with a thermaltake silent purepower from 2004 powering a 3ghz Pentium 4 with a Silverstone sst nt01 and a winfast px8500
entirely silent
until the test HDD spun up and made my ears hurt
exactly. i guess the best way still would be to do like linus and stuff the whole pc in the closet to shut it up.
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394666
I still don't know what you're going to power.
Ryzen R7 2700
Zotac RTX 2080 8gb twin fan
A few ssd a few external hdd
An aio 120mm
O
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394678
Pcthemes lists a coolermaster V850 for $149, it's overkill but pretty cheap.
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394688
Do not mix fanless components with cramped form factors.
For a silent build with some fanless componentes, a larger case with more space for air to flow properly would be a better option.
Also, Corsair's ML fans are not even close to being the most silent fans on the market right now, even some ball bearing options can be quieter.
Project Diesel 5.0: Motherboard: ASRock Fatal1ty X370 Professional Gaming /// CPU: Ryzen 5 3600X  /// CPU Cooler: Scythe Ninja 5 /// GPU: Zotac AMP Extreme RTX 2070 /// RAM: 2x 16gb G.Skill Ripjaws V @3200mhz /// Chassis: Lian Li Lancool One Digital (black) /// PSU: Super Flower Leadex III 750w /// Storage: Inland Premium 1TB NVME + Toshiba X300 4TB
Peripherals: Mice: Cooler Master MM720 /// Keyboard: Corsair K70 MK2 SE (Cherry Silver), Blitzwolf BW-KB1 (Gateron Reds) /// Monitor: Acer XZ320Q 32' (VA, 1080p @240hz) /// AMP: Topping PA3 (Onkyo Integra A-817XD undergoing restoration) /// DAC: Weiliang SU5 /// Speakers: AAT BSF-100 /// Mike: Alctron CS35U /// Headphones: Blon B8, ISK MDH-9000
Living room: TV: Samsung QLED Q7FN 55' 4k /// Amplifier: Denon AVR-X2400H /// Speakers: DALI Zensor 7 /// Consoles: Sony PS4 Pro 1TB, Sony PS3 500gb /// LD/CD/DVD: Pioneer DVL-909 /// Power Supplies: Upsai ACF-2100T + GR Savage CDR2200EX
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394695
But is it quiet?
O
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394723
1 hour ago, SGTechGamer said:
Ryzen R7 2700
An aio 120mm
The SG13 seems to support ATX PSUs up to 15cm long. The Bitfenix Formula is 14cm long, but non-modular.
https://www.cybenetics.com/a/K4g/
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394780
But is it quiet?
https://www.techpowerup.com/reviews/CoolerMaster/V850/6.html techpowerup's review says yes.
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394876
Modern fanless need airflow. You do not have that.
Besides that, I see some huge Problems in your build, if you want it really quiet:
silverstone sg13
That is not really possible to get it really quiet in that size. The best way might be an SFX PSU with the Silverstone PP08 Adaptorbracket, mount the PSU as high as possible and use a mediocre Aircooler. Something like NH-L12 Should be possible. That Heatsink is good for around 100W or so.
Well, what's the Hardware inside??
Everything already purchased??
"Hell is full of good meanings, but Heaven is full of good works"
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394959
One of these Seasonics would be a good choice:
SeaSonic FOCUS Plus 650 Gold SSR-650FX
SeaSonic SSR-650FM
SeaSonic SSR-650PX
Seasonic SSR-650SGX
Although 550W would be plenty, I bumped you up a bit for "future proofing" and to keep the fan in silent mode longer, however, you could flip it and keep it in active mode if you need to remove heat from the system. PCPartPicker says these will fit, but you'll need to double check. The SSR-650SGX  is only 125mm, so this may be the best choice.
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394962
Modular PSU take a lot more space than the dimensions sugest. People tend to forget the Connectors!
And they are usually another 10mm or so...
Lower Wattage Formula come with only 2 Drive Cables anyway, so there isn't much left to manage. And for that there is ziptie. With that the PSU takes way less space than a modular one.
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12394966
If price doesn't matter at all, I'd use the NH-L12 as a CPU Cooler and the Silverstone Nightjar NJ450-SXL as a PSU.
And you need to purchase the PP08 SFX in ATX Bracket as well. That should be the best....
If you care a bit about Money, a SST-SX500-G would do the job.
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12395077
My PC can be silent if I turn most of the fans off?, if you can actually find fans that can run silent at max or mid power then pls send them to me, also you will need to use ssd storage not hhd becauses they are loud.
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12395433
I have a few silent fans, bequiet fans are pretty quiet and if you can't get your hands on those I recommend the corsair ml 120/140 pros rgb or non rgb up to you.
My favorite is still bequiet's silent wings3 but if you're on a pure wings2 will do fine
O
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12397617
Can you run them at a good RPM with them silent
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12416985
Yes I never let em pass 1600rpm
O
https://linustechtips.com/topic/1044620-silence-build-question/#findComment-12418326
