Hello all, i need help deciding which monitor to get. currently i have a gtx1060 which i plan on upgrading soon. i currently just play dota 2.
my choices are https://www.msi.com/Monitor/Optix-MAG271CQR
or https://www.asus.com/ph/Monitors/VG279Q/
The asus is $100 cheaper in my location.
Asus is 1080p IPS 144hz
MSI is 1440p 144hz VA
The main use for the monitor im getting is for Dota 2 and watching netflix/movies
Im also open for new monitor suggestions just please keep it on the same price range.
bonus question, doesnt need to be answered. will i get the same fluidity on the 144hz monitor im getting as a smart tv?
Thank you!
https://linustechtips.com/topic/1044404-decision-help/
I personally try to stay away from VA pannles. I would go with the Asus monitor for sure. In Dota the Jungle on the VA would be darker than it already is lol.
Also TV vs Monitor, Monitor will pretty much always win. They are designed for it! 144hz Gaming is life-changing, and you just don't go back to slower after it.
PC Set up
CPU: I9-9900k
Mobo: Gigabyte Z390 Aorus Pro-Wifi
GPU: MSI RTX 2070 Gamin Z
Cooling: Cooler Master ML360R AIO
RAM: Corsair Vengeance Pro RGB 16 GB 3000MHZ (8GB X 2)
RAM: Corsair Vengence Pro Lighting Enhancement Kit (0GB X 2)
Storage: Samsung 860 EVO 1TB
PSU: EVGA SuperNova G2 750 W 80+ Gold Fully Modular
Case: CoolerMaster MB511 RGB
Build Log found here:
https://linustechtips.com/topic/1044404-decision-help/#findComment-12392865
Ohh ok. Thought the jump to 1440p will be worth it.
my question about the comparison to TV is about netflix not gaming. When i watch netflix on a smart tv, will i get the same fluidity on the 144hz when watched thru a pc? Thanks
https://linustechtips.com/topic/1044404-decision-help/#findComment-12392883
Yep! also the jump to 1440p is nice, but not worth it if the panel is VA. The colors are really bad IMO. Its also not worth if you have an old GPU. It will add more stress on it.
PC Set up
CPU: I9-9900k
https://linustechtips.com/topic/1044404-decision-help/#findComment-12392891
