Hyper 212 Thermal Paste
Go to solution Solved by DarrenP,
More than fine to use.
(Sorry if this is in the wrong place)
I'm buying a Cooler Master Hyper 212 evo to replace my AMD Stock Heatsink and was  wondering  if the Thermal Paste (or Thermal Compound) that comes with the Hyper 212 is just fine to use? Thanks in advance!
Specs:  CPU- AMD FX 8320 @ 3.5Ghz Cooler: Hyper 212 Evo Motherboard: GIGABYTE GA-990FXA-UD3 GPU -EVGA GeForce GTX 970 4GB Superclocked  RAM- 16GB 1600MHz (4x4)  HD- Western Digital Blue Hard Drive 1TB  PSU - Corsair CX 750M Case: Corsair 300R OS-  Windows 7 Home Premium 64 bit Mouse: Razer Deathadder 2013 Keyboard: Razer Blackwidow Ultimate Edition 2013
https://linustechtips.com/topic/104354-hyper-212-thermal-paste/
Please quote/tag ( Found by typing @DarrenP) In all posts directed at me. I do not check my current content.
Intel Core i7-4790K - Gigabyte Z97X-UD5H-BK - 16GB Corsair Vengeance Pro 1866Mhz - EVGA GTX 980 - 256GB MX100 - 2TB WD RED - 900D - H100I - Corsair HX1050 - DNS 320L 2x2TB Seagate Barracuda
https://linustechtips.com/topic/104354-hyper-212-thermal-paste/#findComment-1395749
It good but I didn't use it on mine because I accidentally bought arctic silver 5 :D
Hope I could help!
Specs: CPU: AMD FX-8320 @4.0ghz GPU: ASUS DCUII GTX 770 PSU: EVGA Supernova 750g CASE: Fractal Define R4 RAM: 8 Gigabytes ADATA 1333 Mhz MOBO: GIGABYTE GA-990FXA-UD3
https://linustechtips.com/topic/104354-hyper-212-thermal-paste/#findComment-1395757
Ok, thanks!
https://linustechtips.com/topic/104354-hyper-212-thermal-paste/#findComment-1395765
It's fine to use, nothing wrong with it.
CPU: Intel core i5 3570 Motherboard: Gigabyte-H77-DS3H Case: Fractal Design Define R4 Storage: Seagate Barracuda 2TB  GPU: MSI Radeon HD 7950 Twin Frozr III Cooler: CM Hyper 212 Evo RAM: Crucial Ballistix Sport 16GB  PSU: Seasonic G Series 550W
Acer Aspire S7 Overview Sennheiser PC360
https://linustechtips.com/topic/104354-hyper-212-thermal-paste/#findComment-1395766
The difference in temperatures that you get from the highest end thermal paste and the ones you get included with heat sinks is very small. So yes it is completely fine to use.
CPU:Ryzen 9800X3D GPU: RTX 5080 MB: Asus ROG X870E  RAM: G.Skill Trident Neo 64gb CPU Cooler: ROG Ryujin III
https://linustechtips.com/topic/104354-hyper-212-thermal-paste/#findComment-1395767
Perfectly perfect. I used it and have had no problems.
Life is pain. Anyone who says any different is either selling something or the government.
----CPU: FX-6300 @ 4.2ghz----COOLER: Hyper 212 EVO----MOBO: MSI 970A-G46----PSU: OCZ 600watt----CASE: Black Corsair C70----GPU: Sapphire 7870 dual fan ghz edtion----2 random HDD'S----A couple fans here and there. Mouse: Gigabyte M6900-------Keyboard: Logitech G105-----Mousepad: Steel series something something.
https://linustechtips.com/topic/104354-hyper-212-thermal-paste/#findComment-1395790
Same :D
#LinusKitchenTips /// "Better than useless" - Linus Sebastian
LTT Holy bible: Code Of Conduct
Project Toaster [My Silver NCASE M1 V2 Build-log]
Main Rig
 Case: Fractal Design Define R5 CPU: INTEL
i5 3570k Cooler: CM Hyper 212 Evo Mobo: Maximus V Gene Z77 GPU: Gigabyte GTX 970 G1 Gaming (w/ 0% fan mode) RAM: Corsair Dominator Platinum 2x8GB 1600mHz Storage: OCZ VERTEX 4 256GB PSU: Corsair AX860 Monitor: ASUS PB278Q 1440p 27" Headphones: QPAD QH-90 Laptop
Macbook Pro Retina 13" i5 256Gb Early 2015
Phone
Oneplus One 64GB Sandstone Black
https://linustechtips.com/topic/104354-hyper-212-thermal-paste/#findComment-1395851
