Hi all, I was just wondering if anybody would know if the CPU header on a zenith extreme which is rated at 1 amp was running enough power through it to power up a 3 fan aio CPU cooler? I'm plugging the fans into this header and nothing seems to be happening?? But they go if I plug them into my sata powered fan hub?? I'm confused
https://linustechtips.com/topic/1043138-zenith-extreme-cpu-header/
Need to know what fans they are. Fans are rated to draw different amount of power. Usually in 0.05-0.7A range. Most modern fans should be fine to have 3 in single header. If they work from SATA powered hub, but not from the header, then its likely that they are overpowering header. Test if 2 of them work.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
