1 minute ago, Willis Gambino said:
I have an intel i5-4460, 8gb of ddr4 ram, evga 600w psu. Like I said I'm new to computers that all I know
What games are causing you problems?
Stinkpci5 3550. DDR3 1600mhz 8GB. Gigabyte GA-H61N-USB3.0. Sapphire RX 570 Nitro 4GB oc. Noctua NH-L12. WD Black 600GB. Silverstone PSU 1KW. Advent 1440x900 75hz VGA monitor 1ms. Acer Veriton M464 chassis.
Self help guide.
https://linustechtips.com/topic/1043022-need-help/#findComment-12380177
I just installed the card and I have only played Insurgency sandstorm, and subnautica. My old gtx 760 though on lower settings still managed more consistent frames.
You may be going too high in FPS and the CPU is capping out, tries limiting your FPS with Vsync or using MSI afterburner?
Self help guide.
https://linustechtips.com/topic/1043022-need-help/#findComment-12380186
Just now, Willis Gambino said:
I do have afterburner installed I'll look into limiting fps that way,  what other things could be causing it?
Nothing else, it is consistent with my theory because the 760 is a much slower GPU which keeps frame times in a steady state even if FPS is lower, because FPS fluctuates so high you will hit hard limits of the CPU and game engine faster bringing you stutter and inconsistent frame times.
Self help guide.
https://linustechtips.com/topic/1043022-need-help/#findComment-12380195
2 minutes ago, Willis Gambino said:
I'm playing bad company 2 rn and I'm getting like 160 fps on high settings amd is running perfectly smooth. Could it just be the games?
Not all games use the CPU the same way and BFBC2 is an older game in comparison to what specification is needed to push another modern game optimally.
BFBC2 also scales brilliantly on 4 cores.
Self help guide.
https://linustechtips.com/topic/1043022-need-help/#findComment-12380213
As a final question, do you have any kind of money to put forwards for an improvement in PC specifications?
The method i have given you will help you, but games will increase in system specification minimums in order to play them.
Self help guide.
https://linustechtips.com/topic/1043022-need-help/#findComment-12380226
Yea I do just didnt realize how expensive all this is
It is entirely up to you if you want to stick to my method or upgrade your entire platform, the upgrade i will present to you will last for a long time and not cost the Earth, but it may be substantial depending on your budget.
Self help guide.
https://linustechtips.com/topic/1043022-need-help/#findComment-12380233
What should I get then?
You can reuse your power supply, case & HDD's, you have DDR3 memory so you will need DDR4 memory of which i have listed for you, this is based on USA buying, i assume you are a resident of the USA? If not i can change this to suit your currency.
CPU: AMD - Ryzen 5 2600 3.4 GHz 6-Core Processor  ($164.89 @ OutletPC)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard  ($64.99 @ Newegg)
Memory: G.Skill - Aegis 16 GB (2 x 8 GB) DDR4-3000 Memory  ($79.99 @ Newegg)
Total: $309.87
Generated by PCPartPicker 2019-03-10 20:17 EDT-0400
Self help guide.
https://linustechtips.com/topic/1043022-need-help/#findComment-12380238
Yea this is a good start thanks for the help
No problem. :)
Self help guide.
https://linustechtips.com/topic/1043022-need-help/#findComment-12380241
Before you buy ANYTHING, have you uninstalled and reinstalled the GPU drivers with DDU? Just upgrading the GPU and installing new drivers doesn't necessarily get rid of the old ones. This may help out a lot.
CPU: i7 4790k @ 4.7 GHz
GPU: XFX GTS RX580 4GB
Cooling: Corsair h100i
Mobo: Asus z97-A
RAM: 4x8 GB 1600 MHz Corsair Vengence
PSU: Corsair HX850
Case: NZXT S340 Elite Tempered glass edition
Display: LG 29UM68-P
Keyboard: Roccat Ryos MK FX RGB
Mouse: Logitech g900 Chaos Spectrum
Headphones: Sennheiser HD6XX
OS: Windows 10 Home
https://linustechtips.com/topic/1043022-need-help/#findComment-12380261
An i7 4770 would be a nice upgrade if it turns out your CPU is bottlenecking the graphics card. They can be found on eBay for a little over $140 or so. Also, pretty sure you have DDR3 in that rig, not DDR4.
Edit: I just looked up used Ryzen prices and they're pretty awesome
https://www.ebay.com/itm/AMD-Ryzen-5-1400-3-2GHz-3-4GHz-Turbo-Quad-Core-Processor-CPU/264231563391?hash=item3d856db07f%3Ag%3AsIsAAOSwejNcg7hG&LH_BIN=1
so yeah if you want to switch to some DDR4 and a cheap B350 motherboard it's not a bad move.
(btw make sure to quote people so they see your responses)
Edited by fasauceome
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1043022-need-help/#findComment-12380657
