Hello guys,
I have  5 years old PC  and I want upgrade RAM and GPU, can you please reccomend something to me (something that will not be bottlenecked) ?  I use pc for graphic design( Affinity Photo/Designer, Sketch) and gaming(Apex, PUBG etc..)
I also dont like new  AMD crimson software so I would preffer nVidia :)
Current PC Specs:
Cpu: Intel i5 3570k + cooler GELID Tranquillo rev. 2
Motherboard: MSI Z77A-G45
RAM: Geil DDR3 8GB (2x4GB) 1866MHz EVO CORSA CL9 GOC38GB1866C9DC
PSU: Seasonic SS-650HT 80+ F3 A.PFC
GPU: Sapphire HD 7870 OC
https://linustechtips.com/topic/1042533-help-with-upgrade/
34 minutes ago, Qwertin said:
Hello guys,
Current PC Specs:
Cpu: Intel 3570k + cooler GELID Tranquillo rev. 2
are you sure that you dont need a cpu upgrade?
gaming system: Intel core I9 12900ks / biostar Z690A valkyrie / 4x8gb corsair Vengeance @3333Mhz ram / RX 7900XTX pulse gpu / Thermalright peerless assassin 140 /Coolermaster Qube 500 case / Be Quiet Dark Power Pro 12 1500w power supply
laptop: Dell xps 9510, 3.5k OLED, i7 11800h, rtx 3050 ti, 2x16gb DDR4 @ 3200Mhz, 1TB main drive, 2TB add in ssd
https://linustechtips.com/topic/1042533-help-with-upgrade/#findComment-12376068
check how much 8GB of used DDR3 will cost you and also comparing to DDR4 prices first, if your region doesnt have good deals here, it's better to just start over on a DDR4 platform.
old enough to go when changing platforms
RX 570/580 because 1060 6gb are too darn costly in most places, except when it isn't of which you should go Nvidia
not a problem tbh since you can manage the hardware side of things with OC tools like Afterburner. Nvidia's Control Panel is as bad if not worse than AMD Wattman
Desktop benching:
https://linustechtips.com/topic/1042533-help-with-upgrade/#findComment-12376116
The Affinity programs have only minimal requirements. Is Sketch the same as SketchUp? If so, the SketchUp recommended hardware is:
Recommended hardware
  • 2+ GHz processor
  • 8+ GB RAM
  • 700MB of available hard-disk space
  • 3D class video card with 1 GB of memory or higher and support for hardware acceleration. Please ensure that the video card driver supports OpenGL 3.0 or higher and is up to date.
    SketchUp's performance relies heavily on the graphics card driver and its ability to support OpenGL 3.0 or higher. To test your graphics card's compatibility, please download and run the SketchUp Checkup application. Historically, people have seen problems with Intel-based cards with SketchUp. We don't recommend using these graphics cards with SketchUp at this time.
It looks like the gaming requirements will dictate your recommended hardware.
https://linustechtips.com/topic/1042533-help-with-upgrade/#findComment-12376127
Yes I meant SketchUP,  if its possible to avoid building new pc ... I will avoid it, but I also dont want scenario that gpu will be bottlenecked ... ? I dont spend too much time gaming now ... and as I said  I play mostly Apex, PUBG, DOTA 2 .... but there is also dilema "is it worth to invest in graphic card to this PC ? "  from economic side of thing....  to be honest am confused   ?.
https://linustechtips.com/topic/1042533-help-with-upgrade/#findComment-12376193
