7 minutes ago, RJ56Hours said:
Anyone have any idea?
You mind giving some detail? Maybe your cable connection is bad, try plugging it into your monitor/display output again. Have you tried using another cable? What's your PC's specs? What monitor do you have?
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1042484-help/#findComment-12375674
I have a 1600x OC to 3.9Ghz, recently updated a Msi trio rtx2080ti, in fact just 2 days ago. Got a brand new firecuda to load my Win10, it's yesterday. I too changed it to a 1000w Rmx PSU. B350F as my MB. A regular samsung 1920x1080 monitor. Was playing Rainbow 6 then it crashed, my monitor didn't detect any signal. After that, the fans just started to get very loud. My gpu is manufactured in Jan2019, i hope it's not the memory problem. I underclocked it 150Mhz and it still have the problem.
https://linustechtips.com/topic/1042484-help/#findComment-12375716
And it's not the cable problem.
https://linustechtips.com/topic/1042484-help/#findComment-12375722
