Airflow speed limits?
By
Phil Jermakian
in Cooling
in Cooling
Solved by fluxdeity,
Your case will pull the air in from wherever else it can. What you can do is get a program to change fan speeds if they are PWM, or try changing the speeds in BIOS/UEFI.
4
Greasy_Pudding ·
Sveeno ·
Posted in LTT Releases7 -
3
thrasher_565 ·
Posted in Hot Deals0 -
6
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
11
derekchan ·
Posted in New Builds and Planning19
play_circle_filled
Latest From ShortCircuit:
