Help with sorting algorithm in javascript
Go to solution Solved by RushFan,
It was just because java(script?) references objects when you make them equal to another one so I just made a new temporary one.
NEW CODE:
tri[] fintris = new tri[calctris.length];
  for(int i = 0; i < fintris.length; i++){
    int maxCnt = 0;
    float maxVal = 0;
    for(int i1 = 0; i1 < calctris.length; i1++){
      if(maxVal < calctris[i1].a.z){
        maxCnt = i1;
        maxVal = calctris[i1].a.z;
        fintris[ i] = new tri(new vert(calctris[i1].a.x, calctris[i1].a.y, calctris[i1].a.z), new vert(calctris[i1].b.x, calctris[i1].b.y, calctris[i1].a.z), new vert(calctris[i1].c.x, calctris[i1].c.y, calctris[i1].a.z));
    calctris[maxCnt].a.z = 0;
Hi, so I'm trying to make a sorting algorithm which copies one array into another but sorts it from highest to lowest. I don't understand online examples very much so I thought I'd ask here. (also I'm not a very experienced programmer so my code is probably going to be messy and probably not very good)
I have a class called tri(for storing triangle data) and I'm sorting it based on its '.a.z' value.
(calctris[] has already been made)
the code for the (not working) current one is:
  for(int i = 0; i < calctris.length; i++){
    int maxCnt = 0;
    float maxVal = 0;
        maxCnt = i1;
        fintris = calctris[i1];
it's just filling the new array with 0.0;
-Parts-
Core i7 8086k 4.0GHz (4.6GHz OC) - ASUS z390 ROG Maximus XI code - Corsair H115i - 16GB (2 x 8GB) G.SKILL Trident Z RGB 3600MHz - Windforce GTX 1050Ti - Corsair HX750i - Corsair Obsidian 500D RGB SE
-Upgrades when I get the money-
Undecided on the GPU - ASUS ROG PG278QR 1440p 144Hz (165Hz OC)
https://linustechtips.com/topic/1041806-help-with-sorting-algorithm-in-javascript/
While I shouldn't be helping you with your CS homework here's some bubble sort code I made. Hopefully it should help you as I'm not going to solve it for you. You gotta learn ;)
#include-once
#include <AutoItConstants.au3>
; #FUNCTION# ====================================================================================================================
; Name ..........: BubbleSort
; Description ...: Sorts a 1 or 2 dimensional array using the BubbleSort Algorithm
; Syntax ........: BubbleSort($_aArray[, $_bAscending = True])
; Parameters ....: $_aArray             - [in/out] The 1 dimensional array to sort.
;                  $_bAscending         - [optional] Sort by increasing values. Default is True.
; Return values .: Success - Returns 1
;                  Failure - Returns 0 and sets @error:
;                  |1 = Invalid Array, sets @extented: (1, if not a valid array; 2, if not 1 or 2 dimesional)
;                  |2 = Invalid $_bAscending Flag
; Author ........: Robert C. Maehl (rcmaehl)
; Modified ......: 11/30/2015
; Remarks .......: To do: Complete Two Dimesional Array sorting ([first,first] = lowest, [last,last] = highest)
; Related .......:
; Link ..........:
; Example .......: No
Func BubbleSort(ByRef $_aArray, $_bAscending = True)
    Local $_vReturn = Null
    Local $_bFinished = False
    If Not IsArray($_aArray) Then SetError(1,1,0)
    If UBound($_aArray, $UBOUND_DIMENSIONS) > 2 Then SetError(1,2,0)
    If Not IsBool($_bAscending) Then SetError(2,0,0)
    If $_vReturn = Null Then
        If UBound($_aArray, $UBOUND_DIMENSIONS) = 1 Then
            While Not $_bFinished
                $_bFinished = True
                $_iLoop = 0
                $_vTemp = 0
                If $_bAscending Then
                    For $_iLoop = 0 To UBound($_aArray) - 2
                        If $_aArray[$_iLoop] > $_aArray[$_iLoop + 1] Then
                            $_vTemp = $_aArray[$_iLoop]
                            $_aArray[$_iLoop] = $_aArray[$_iLoop + 1]
                            $_aArray[$_iLoop + 1] = $_vTemp
                            $_bFinished = False
                        EndIf
                    Next
                Else
                        If $_aArray[$_iLoop] < $_aArray[$_iLoop + 1] Then
                            $_bFinished = False
                        EndIf
                    Next
                EndIf
            WEnd
        Else ; 2 Dimesional Sorting, Not Yet Complete. (Sort all rows & columns with [0,0] with smallest, and [last,last] with largest)
            $_iLoop1 = 0
            For $_iLoop1 = 0 To UBound($_aArray, $UBOUND_ROWS) - 1
                $_bFinished = False
                    $_bFinished = True
                    $_iLoop2 = 0
                    $_vTemp = 0
                        For $_iLoop2 = 0 To UBound($_aArray, $UBOUND_COLUMNS) - 2
                            If $_aArray[$_iLoop1][$_iLoop2] > $_aArray[$_iLoop1][$_iLoop2 + 1] Then
                                $_vTemp = $_aArray[$_iLoop1][$_iLoop2]
                                $_aArray[$_iLoop1][$_iLoop2] = $_aArray[$_iLoop1][$_iLoop2 + 1]
                                $_aArray[$_iLoop1][$_iLoop2 + 1] = $_vTemp
                                $_bFinished = False
                            EndIf
                        Next
                    Else
                            If $_aArray[$_iLoop1][$_iLoop2] < $_aArray[$_iLoop1][$_iLoop2 + 1] Then
                                $_bFinished = False
                            EndIf
                        Next
                    EndIf
                WEnd
            Next
        EndIf
    EndIf
EndFunc
PLEASE QUOTE ME IF YOU ARE REPLYING TO ME
Desktop Build: Ryzen 7 2700X @ 4.0GHz, AsRock Fatal1ty X370 Professional Gaming, 48GB Corsair DDR4 @ 3000MHz, RX5700 XT 8GB Sapphire Nitro+, Benq XL2730 1440p 144Hz FS
42U Server Rack: ISP Modem + UDM-SE + APC 3kVA UPS + 3x Dell Precision 5820 + TBD
Retro Build: Intel Pentium III @ 500 MHz, Dell Optiplex G1 Full AT Tower, 768MB SDRAM @ 133MHz, Integrated Graphics, Generic 1024x768 60Hz Monitor
#include-once
; Related .......:
; Link ..........:
                $_bFinished = True
                $_iLoop = 0
                $_vTemp = 0
                            $_bFinished = False
                        EndIf
                    Next
                Else
                            $_bFinished = False
                        EndIf
                    Next
                EndIf
            WEnd
            $_iLoop1 = 0
                $_bFinished = False
                    $_bFinished = True
                    $_iLoop2 = 0
                    $_vTemp = 0
                                $_bFinished = False
                            EndIf
                        Next
                    Else
                                $_bFinished = False
                            EndIf
                        Next
                    EndIf
                WEnd
            Next
        EndIf
    EndIf
EndFunc
I was more hoping for someone to explain what was wrong with the one I made, but thanks
(also this isn't homework, just part of a side project that I'm having fun with)
-Parts-
11 minutes ago, MrMG said:
Are you sure you are coding with Javascript? I don't know much about Javascript but your code looks more like Java code to me.
Idk honestly, I'm using processing and I thought it was javascript
-Parts-
I have no idea what processing is but according to wikipedia it has a Java like syntax, but uses Javascript for rendering on webpages.
I have looked at your code and I have found one thing that might be wrong:
This line inside your second for loop, might be wrong. As far as I know fintris is an array and that line should look something like:
fintris[i1] = calctris[i1];
Not sure if that solves your problem though.
That was an issue, but I found the problem and it was something else
-Parts-
NEW CODE:
    int maxCnt = 0;
    float maxVal = 0;
        maxCnt = i1;
-Parts-
NEW CODE:
    int maxCnt = 0;
    float maxVal = 0;
        maxCnt = i1;
        fintris = new tri(new vert(calctris[i1].a.x, calctris[i1].a.y, calctris[i1].a.z), new vert(calctris[i1].b.x, calctris[i1].b.y, calctris[i1].a.z), new vert(calctris[i1].c.x, calctris[i1].c.y, calctris[i1].a.z));
Ik that can be done better but shhhh alright ik what I need to do
-Parts-
NEW CODE:
    int maxCnt = 0;
    float maxVal = 0;
        maxCnt = i1;
also there is an [i ]  after fintris but this forum thinks it's me trying to make it italic
-Parts-
Just now, MrMG said:
Great to hear that you found the solution. If you want to add code to your posts, then consider using the code tags:
That way everything should be copied correctly.
Ok, I'll keep that in mind if I have any more questions about my code
-Parts-
#include-once
; Related .......:
; Link ..........:
                $_bFinished = True
                $_iLoop = 0
                $_vTemp = 0
                            $_bFinished = False
                        EndIf
                    Next
                Else
                            $_bFinished = False
                        EndIf
                    Next
                EndIf
            WEnd
            $_iLoop1 = 0
                $_bFinished = False
                    $_bFinished = True
                    $_iLoop2 = 0
                    $_vTemp = 0
                                $_bFinished = False
                            EndIf
                        Next
                    Else
                                $_bFinished = False
                            EndIf
                        Next
                    EndIf
                WEnd
            Next
        EndIf
    EndIf
EndFunc
What in the heck is AutoIT? I had to google the .au3 file extension. This looks like Visual Basic but even more atrocious. I'm shook.
Current PC build: [CPU: Intel i7 8700k] [GPU: GTX 1070 Asus ROG Strix] [Ram: Corsair LPX 32GB 3000MHz] [Mobo: Asus Prime Z370-A] [SSD: Samsung 970 EVO 500GB primary + Samsung 860 Evo 1TB secondary] [PSU: EVGA SuperNova G2 750w 80plus] [Monitors: Dual Dell Ultrasharp U2718Qs, 4k IPS] [Case: Fractal Design R5]
