Hello im building a pc right now With the H500p case and z270 gaming pro carbon mother board and Ma610p cooler
I have some problems plugging the fans cables :
1. My cpu cooler has 2 cables one plugs to cpu fan header the other is in the picture I Dont know where to plug it
2.my motherboard has sys fan and pump fans header idk the difference
3. 2 cables coming from front fans , one of them idk what it is
From Cpu cooler
Coming from Front Panel Fans :
https://linustechtips.com/topic/1041776-fans-cables-connecting/
Hi!
1 - The other cable seems to be a RGB header cable. It will allow you to control lightning of the cooler :)
2 - CPU pump is required only if you're using a watercooling system with a pump. You'll only need to connect CPU fan if you are air cooling it.
3 - The cable on the second picture is an old fan cable, you'll find adapters if your MB doesn't have the right headers.
I hope this helps !
Just another engineer posting useful hardware videos directly to the interconnected network (AKA the internet)
Tech enthusiast. Check my channel out here https://www.youtube.com/channel/UC6FU1nfeGBBnw_bvHgWCqTQ
https://linustechtips.com/topic/1041776-fans-cables-connecting/#findComment-12369824
25 minutes ago, Insorior said:
Hi!
I hope this helps !
Thanks I understood the first ,
The front panels fans are connected to one cable whoch has 2 cables one I connected to sys fan and the second that you said is an old cable should I ignore the second ?
https://linustechtips.com/topic/1041776-fans-cables-connecting/#findComment-12369883
