Popping sound inside PC case.
Go to solution Solved by Wormhole,
probably just metal expanding and shrinking my case does that sometimes
About once a day, when using my computer, I'll hear a loud pop come from inside my case. It sounds like the metal in my case shifting, and initially, I thought that it was that, but now I'm getting kind of worried. Everything seems to be working fine. It does not sound like its coming from my PSU, so I think its something else. Any ideas?
https://linustechtips.com/topic/1041585-popping-sound-inside-pc-case/
(◣_◢) Ryzen 5 3600,   Aorus X370 K7,   XPG 16GB 3200,   Gigabyte 2070 Windforce Corsair RM650x,   LG 32GK650F-B 31.5" 144Hz QHD FreeSync VA,   Kingston 120GB SSD,   Samsung 1TB 860 QVO,   2TB HDD,   Fractal Design Meshify C,   Corsair K63 Wireless,   Corsair Gaming M65 PRO,   Audio Technica ATH M50x,   Windows 10 ProCorsair H100x 240mm.  (◣_◢)
(◣_◢) Ryzen 5 1600,   Noctua NH-L12S,   Gigabyte GTX 1060 6G,   ASUS Prime B350 Plus,   HyperX Fury 8GB DDR4 (2666MHz - 1.3v),   SilverStone ET550-B,   Kingston 120GB SSD 2TB HDD,   Cougar MX330,   Windows 10 Pro.  (◣_◢)
