hi, am gonna buy a Varmilo VA88M Panda and it has a microUSB to usb cable, does a wireless adapter exists ? microUSB to usb wireless/bluetooth
(edit) damn am stupid, i did not think about the keyboard gonna need power .-. , but the question til sand, and is it away around it ?
https://linustechtips.com/topic/1040648-wireless-layboard/
A bit off topic but isn't it better to buy wireless keyboard in the first place? Adapter exists, but it does not solve all your problems.
https://linustechtips.com/topic/1040648-wireless-layboard/#findComment-12359333
3 minutes ago, myselfolli said:
Why would you though? If you want a wireless device, buy a wireless device, otherwise you'll be out of luck really...
probably in 99% cases, it would be, but am really picky on my keyboard, just was wondering if it is at all possible to do, and what i can find it is, but a heck of a lot of work so just gonna make custom cable instead xD
https://linustechtips.com/topic/1040648-wireless-layboard/#findComment-12359343
