Same issue after GPU RMA...Anyone?
Go to solution Solved by SkyHound0202,
You need to disable OSD function in EVGA Precision XOC.
2 minutes ago, Blademaster91 said:
The OSD function in EVGA XOC can be really buggy, also give DDU a try and clean install GPU drivers.
goddamit ...I rmaed a perfectly good gpu...face palm...many thanks guys
Yes, yes you did. But you didn't know better at the time. You've learned something new! I'm pretty sure that bar is used for frame rate measurements.
