I think I’ve decided to go with a 2600x and want a motherboard that will be good enough to put the 2020 Ryzen 7 in. Not to sure what way to go as I don’t know much about motherboards I was looking at these too they are both 179.99
Asus Rog Strix b450-f gaming
ASRock X470 master
I would be open to spending $50 or so more
https://linustechtips.com/topic/1039973-mobo-help/
Where are you buying from? Worst deal ever in the US if that's in USD, still so in CAD, so...
Desktop benching:
https://linustechtips.com/topic/1039973-mobo-help/#findComment-12354080
9 minutes ago, Matthewbarkhouse said:
I’m in Canada
The B450 Tomahawk is a good choice at around C$170.
CPU: Intel Core i7-950 Motherboard: Gigabyte GA-X58A-UD3R CPU Cooler: NZXT HAVIK 140 RAM: Corsair Dominator DDR3-1600 (1x2GB), Crucial DDR3-1600 (2x4GB), Crucial Ballistix Sport DDR3-1600 (1x4GB) GPU: ASUS GeForce GTX 770 DirectCU II 2GB SSD: Samsung 860 EVO 2.5" 1TB HDDs: WD Green 3.5" 1TB, WD Blue 3.5" 1TB PSU: Corsair AX860i & CableMod ModFlex Cables Case: Fractal Design Meshify C TG (White) Fans: 2x Dynamic X2 GP-12 Monitors: LG 24GL600F, Samsung S24D390 Keyboard: Logitech G710+ Mouse: Logitech G502 Proteus Spectrum Mouse Pad: Steelseries QcK Audio: Bose SoundSport In-Ear Headphones
https://linustechtips.com/topic/1039973-mobo-help/#findComment-12354117
20 minutes ago, Matthewbarkhouse said:
I’m in Canada
Get MSI X470 Carbon if possible ($240), but otherwise the MSI B450 Tomahawk ($150) is the best choice. More expensive boards that dont go past $230 budget just arent significantly better
Desktop benching:
https://linustechtips.com/topic/1039973-mobo-help/#findComment-12354154
