So i got a Corsair H100i water cooler for my gaming pc, its paired with a (old school) i5 2400. my idle temps are around 50+ degrees C and when i open a game up it jumps to 70 degrees C. Is this normal or should i reapply thermal paste (btw im using cooler master high preformance paste)image.png.6984248b296f180756d48536e1b1060a.png
https://linustechtips.com/topic/1039789-somthings-hot/
What was your old cooler?
For starters, you could undervolt instead of repaste.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352758
Those temperatures are quite high. Check that the fans are plugged in and properly spinning on the radiator. Wouldn't hurt to remount it and apply new paste either just to make sure it is mounted properly and has good contact.
Screenshot you posted shows the CPU is on 44% load with 50C temps? That's not really idle... Check for background processes running that are using the CPU.
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352760
thats true but not much difference between temps haha
also im sure they are plugged in cause the thing revs up so loud haha and i checked they are the right way around
is it cause of my installation cause i notice that its hot on one pipe (im new to water cooling)
running so bad when i noticed that there was somthing on my motherboard that is sitting at 70+ temp! I have no idea what it is but its concerning.
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352763
lol I can see you didn't quote my last pose, there's a funny roundabout way for me to see your response.
Motherboard VRMs can get way hotter than semiconductors like your CPU, 125 or even 150 is where you should worry as opposed to 100. And since your motherboard doesn't have a VRM heat sink, they're sure to get hot.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352808
I would venture to say you have poor airflow in your case. The CPU at 45c on idle with watercooling is the first indication of this. The motherboard temps are also very high for being on idle.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352809
Is that fan able to breathe? I can't tell what case you're using but it's possible there's an airflow issue. Is it possible to mount the radiator as an exhaust instead? Worth a shot.
Primary PC:
PSU tier list
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352810
ohhh thank you haha sorry i forgot to quote
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352811
ok ill give that a go cause it is transfering heat haha so its not my thermal paste
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352812
16 minutes ago, Evyn said:
That's not a H100i. Looks more like a H80i?
What case is that? Is it open at the front to allow air flow through the radiator?
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352813
sorry haha idk why i got h100i stuck in my head. yea h80i v2
its a little dusty but other wise not enough to cause that much difference
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352816
Airflow required. Simple as that. Very likely that's the VRMs and having a fan either blowing on them or sucking air off them would help a lot.
Primary Rig:
CPU: AMD 7800X3D @ Stock PBO - Mobo: Gigabyte X670E AORUS Master
2 x 48GB G.Skill Trident Z Royal 6400MHz CL32 1.35V @ 6200MHz CL28-37-32-30 1.5V (still tuning)
CPU Cooler: EK AIO that will be being replaced when I get the chance - PSU: eVGA P2 1200W
GPU: Gigabyte RTX 4090 Gaming OC @ either 2595MHz @ 900mV or 2970MHz @ 1070mV
Case: Thermaltake View 91 - SSDs/HDDs: 1 Samsung 980 Pro 2TB, 2 990 Pro 2TB M.2s, 1 990 Pro 4TB M.2, 1 TeamGroup Cardea Z440 2TB M.2, 1 Seagate EXO X10 10TB HDD
Monitor: Samsung Odyssey G9 49" Super-Ultrawide 240Hz Monitor
https://linustechtips.com/topic/1039789-somthings-hot/#findComment-12352886
