DRAM & NB frequency issue(?)
By
Crawl
in Troubleshooting
in Troubleshooting
Solved by HoneyBadger84,
You're not going to fry your Northbridge/uncore by running it at what is precisely stock, all the time, that's the way you need to look at it. As long as it's not running overclocked or with higher voltage, it won't hurt it at all. It's made to run at that speed after all.
And yes, try setting the min ratio to 8.
HunterSVK ·
Posted in Troubleshooting0 -
Ozzi ·
Posted in Networking2 -
1
MadManMarsBar ·
Posted in Build Logs0 -
IAmAndre ·
Posted in New Builds and Planning7 -
4
3
Playgb2 ·
Posted in Troubleshooting1 -
2
1
play_circle_filled
Latest From ShortCircuit:
