I have an odd issue with a hp 14 r008la notebook when powering on. If you could give me a hand I will appreciate it.
To power it on I have to:
  1. Press and hold power button
  2. Plug in wall charger
  3. Release power after 10 seconds.
Keep in mind it doesn’t turn on if I leave the wall charger plugged in overnight, if I do it won’t start until the next day. The notebook won’t work with battery or while its plugged in.
I have tried:
  1. Different power brick
  2. A new, charged battery
  3. Unplugging and plugging back ram
  4. Opened and checked for water damage, non-visible.
  5. Unplugged, mouse pad, keyboard, wifi module, hdd, display
I believe this may be caused by some component on the board but I don’t know where to start checking.
Thank you in advance.
https://linustechtips.com/topic/1039267-hp-14-odd-power-issue/
Yeah if you've tried unplugging stuff and nothing works the motherboard might be fried. If you can try looking for a new one. There's not much you can really do unless it's a detachable component, try different ram slots if you haven't already. Also maybe check if the wires or connectors for the battery are corroded or broken.
Discord: Skyline#0820
Literally an idiot, don't listen to me.
Main computer: i5-4690k 4.3GHz, Noctua NH-D15, Nitro+ RX 580 SE, 16GB Corsair Vengeance, Samsung 840 series 128GB Crucial MX500 2TB, WD Purple 3TB, EVGA 600w, Dell s2240m 1080p 60hz, Corsair K70 Cherry MX Blue, Logitech G502 Hero.
Asus GU501gm
https://linustechtips.com/topic/1039267-hp-14-odd-power-issue/#findComment-12348597
